Thread: Question about shocking
    May 2012
    Bowling Green, KY
    38
    I am waiting on my TF-100 to arrive and while studying the site - a question came to mind. While going through the shocking process, do I need to concern myself with the other readings (ph, TA, etc.)? Or do I simply need to focus on FC before moving on to adjust the others?
    New to site and thankful for your help.
    30,000 gallon, IG, Vinyl, Sand Filter, Hayward Super Pump - 3450 RPM, 1.5 HP
    South Central Kentucky
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Question about shocking
    TA needs to be above 50 and pH should be in the low to mid 7's before starting the shock process.
    You're done SLAMing when:
    May 2012
    Bowling Green, KY
    38
    OK thank you. So step one is to get TA and ph within those ranges - then proceed to shocking? I hadn't read that anywhere so I really appreciate your help. This site is very helpful to a newbie like myself.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by BCannon
    Yep.
    Welcome to the forum
