Thread: How to remove pollen from bottom of pool?
    Aug 2010
    Northeast Ohio
    20
    I am having problems removing pollen from the bottom of my new pool. I am using the PoolCleaner 4x to vacuum out the pollen, but the pollen passes through the cartridge filter and through the returns back into the pool. I have cleaned the cartridge filters a couple of times and cartridge unit, but still no luck.
    My kids held skimmer sock in front of the returns to capture the pollen, but it only captured some of it.
    I have not tested the water yet, but it looks crystal clear.
    Any suggestions on what to do?
    18 x 36 vinyl IG- 3.5 to 5 ft.- 20,000 gallaons, TF-100 Test Kit, Hayward TriStar Dual Speed 1.5 HP pump, Hayward C3025 SwimClear Cartridge Filter, Hayward SWG, Hayward Heat Pump 21104T, 2 inch PVC, 3 returns, 2 skimmers, 2 Low Suction (no main drain), Dedicated Suction for The Pool Cleaner 4x, Prologic 8 with Aquapod, 2 Colorlogic LED lights, (2) 16 inch sheer descents
    Butterfly's Avatar
    South Carolina
    10,045
    Re: How to remove pollen from bottom of pool?
    If the filter is passing stuff back to the pool then maybe the cartridge has a tear in it or the unit isn't assembled correctly.
    You're done SLAMing when:
    Aug 2010
    Northeast Ohio
    20
    Thanks for your reply.
    I did not notice any tears in the cartridges, and I think I put it back correctly. I will check again, thanks.
    Pollen passing through the filter is usually due to a tear in the cartridge fabric, but can occasionally be caused by the cartridge not seating properly into the filter housing. In the unlikely event that you have a multi-position main valve (not common with cartridge filters) the problem could also be in the main valve.
    It isn't always easy to spot torn filter fabric. It can be buried in one of the pleats where it isn't obvious expect to close examination.
    Aug 2010
    Northeast Ohio
    20
    Thank you both very much for your help!!
    It is fixed!
    The filter plate was not seated correctly.
    Thanks again!
