Thread: Test kits
    May 2012
    Dallas, Texas
    47
    Test kits
    I'm new to taking care of a pool and I'm glad to have found this forum (tons of great info). When having my water tested at my local pool store, I asked if they had a cyanuric acid test kit and they gave me a strip kit to test PH, alkalinity, hardness, CYA, CC and TC. After purchasing I found this forum and only drop kits are recommended. Will the strip kit work or should I return it (unopened) and buy a drop kit?
    15,200 gallon 24' X 52" round AG; installed 2011; SWG
    1 ½ hp Dynamo pump; Pentair Meteor sand filter, 2.1 sq. ft. filtration area, 42 GPM flow rate
    TF 100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Test kits
    Return it and ask them to order a Taylor K-2006. Don't letthem sell you a K-2005, it's not the same.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Test kits
    You'll most likely find a better price and absolute A-1 service at TFTestKits.Net http://tftestkits.net/splash-page.html
    You're done SLAMing when:
    22,550
    Re: Test kits
    Welcome to TFP.
    As Richard said, make sure it has the FAS-DPD chlorine test and not just a DPD test. A lot of people have been told they're the same but they're not. Also, not many stores will have the proper kit.
    Listen to what BF says too.
    May 2012
    Dallas, Texas
    47
    Re: Test kits
    Thanks, I purchased the K-2006 from TFT as Butterfly suggested (best price) and will be returning the AquaChek Select strips to pool store.
    TF 100 Test Kit
