Thread: gas heater thermostat question
    Aug 2009
    SW Wisconsin
    518
    Hey all
    was out getting my pool heater fired up today..had to change out the pressure switch..as the old one went bad, and I got to thinking.....I absolutely HATE the "dial" type thermostat that my heater has on it...I am a "read out" kind of guy and would love to see the actual "number" in degrees on a little digital readout of some sort.......I've replaced thermostats in my home before for the HVAC.......how hard would it be to install sort of an "after market" type of digital thermostat on my pool heater, so I can see the temp, and adjust with push buttons rather than this goofy dial? I mean how hard could it be..as the thermostat on it currently has two wires as a connection and that's it.
    Any thoughts, ideas, or opinions??
    Thanks
    Dan
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    Re: gas heater thermostat question
    I am not aware of any "after market" thermostat replacement for gas pool heaters. What brand/model do you have?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Aug 2009
    SW Wisconsin
    518
    I have a Hayward H200 it's not the electronic ignition..it's got a pilot light in it...has a simple "dial" type thermostat, and It would just be nice to have some read out of temp setting..rather than guessing all the time.
    The simplest approach is to get a remote digital pool thermometer, for example this one, instead of fiddling with the heater.
    Aug 2009
    SW Wisconsin
    518
    I like simple Jason. That may be just the ticket....but I DO like to "tinker" too, and if there were a way to hook up a digital thermostat, and maybe put a temp probe into the return line just after the heater manifold that would be perfect too.
    Dan
