Thread: Parts needed to mod a 2650 sandfilter
    bigorange0711's Avatar
    May 2012
    Southaven Ms
    2
    Can someone give me a set of plans/PVC parts needed to mod a 2650 sandfilter set up to full PVC(No hoses) please
    Intex 16x48 ultra frame pool, Intex 2650 gph sand filter & pump,Hard plumbed fully
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Parts needed to mod a 2650 sandfilter
    Welcome to tfp, bigorange0711
    I think this link may help you: http://www.troublefreepool.com/custo...ls-t28971.html
    racerboy6996's Avatar
    Aug 2010
    Albemarle, NC
    103
    in the link that linen posted, look for the post from Rªzª on June 14, 2011.. that is the method I used.
    Very simple. The part you are looking for is a 1 1/2 conduit box adapter.
    You will then take one of the connectors off of an Intex hose & slide over this adapter before gluing on your PVC pipes.
    Works perfectly
    Intex 16ftx32ftx52in rectangular / Hayward 2 speed pump / Hayward 21in sand filter / Intex SWG / still saying solar panels coming next year
    May 2012
    Southaven Ms
    2
    You need? to use 1 1/4 pvc pipe, 1 1/2 2 way pvc ball valve, and for the connection The part you are looking for is a 1 1/2 conduit box adapter. Pick up some rough grain sandpaper also to sand the end of the PVC pipe to make the box adapter slide over if needed.
    Works perfectly
