Thread: Cloudy pool help. Full tf-100 results posted
    I am really wanting to catch the sparklypoolitis and right now and just frustrated and maybe just impatient.
    The past two days have be very windy adding lots of leaves to the pool I had my mx8 vacuum and hand skimmed them out in the mornings.
    We had about 20 kids in the pool yesterday and the pool was fairly cloudy all day. We can see the bottom but just is not clear. At the end of the day I added a full jug of bleach. ( that is probably why the high clorine today.)
    The pools is a 30000 gallon 20x40 vinyl swg pool. I have a triton tr 100 sand filter and have back washed recently. Here are results.
    Fc 7.5
    Cc 0
    Tc. 7.5
    Ph. 7.5
    Ta. 100
    Ch. 250
    Cya. 5? I have added this over the last month and now it starts to measure slightly. My wife is picking some stabilizer up as I type.
    Temp 82
    How can I get this thing sparkly?
    Under construction DIY 20x40 vinyl liner steel wall pool, Pentair 2hp wisperflo, Pentair tr100 sand filter, Pentair Minimax 400k heater, diving board, 8 foot sit n step, xtream waterslide, 1700 concrete deck, one amazing wife, 4 children and two German shepherds.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,099
    Re: Cloudy pool help. Full tf-100 results posted
    If it's cloudy....you need to shock. How much CYA have you added this last month? We need to first figure out why this number is so low? Most of the other numbers look nice. (but watch the CH levels)
    30,429
    I suspect it is because OP has not ever put any in.
    rhumba, you need to shock your pool. Don't try to do it with the SWG, it is not capable. Bring your CYA up to around 30 and shock the pool according to the article in Pool School.
    Once your water is crystal clear, then bring CYA up to around 60-70 and then turn on SWG to maintain FC around 3-5ppm
    Next big party, increase FC up to about 10ppm BEFORE the party and you will have better success.
    It is a new pool so figured that is why cya is so low. I started with half a container or the Walmart stuff in a sock and after a week there was no difference. Since then I added the rest and now the test is cloudy but doesn't register but I estimate it would if it went to a 5.
    Butterfly's Avatar
    South Carolina
    10,045
    Well, how many gallons is your pool volume and how many pounds of CYA was in the bucket?
    You're done SLAMing when:
