Thread: Can I use a landscaping fountain pump for solar heat panels?
    Mar 2011
    Clearwater, FL
    32
    I would like to set up a separate pump to pump water through the solar panels on my roof only when the sun is out. I have a temperature switch installed and working. I want to have my sand filter and SWG pump turn on by a schedule and not pump water through the solar panels when it's cool.
    I have a landscaping pump someone gave me a few years back.
    Aquascape model SFA3000 2900 GPH @ 5' head, 2.6 amp
    It says right on the label: Thermally protected, this pump is not intended for use in a swimming pool.
    I'm not using it for the filter, just the solar panels. Would this work? Or can someone explain why a pump made for treated stream water can't be used for treated pool water?
    21K gal kidney shape in-ground pool
    Hayward C1200 filter
    Single speed pump
    Re: Can I use a landscaping fountain pump for solar heat pan
    Pool pumps have additional safety requirements, which that pump apparently does not met.
    For solar panels on a roof you need a pump that can pump against a fair bit if dynamic head. That pump is rated at 2900 GPH @ 5' of head. The solar panels are going to be way more than 5' of head, which implies that this pump will not be at all appropriate.
    You can have a separate pump, but it will probably have to be at least a 1/2 HP in-ground pool pump, more if your roof is higher than one story. Still, it is usually easier to get a solar controller and have it run a valve that controls if water goes to the panels or not and use your existing pool pump.
