Thread: When to add salt when shocking
    Aug 2009
    Flower Mound/Texas
    41
    I started with emerald green a few days ago and am now a milky blue green....still can't see the bottom....I'm going to change the filters after I finish writing this....
    Should I wait until I clear up all the algae and then add salt and restart my salt water generator or should I be adding the salt now?
    Here were my readings this morning:
    FC 14.5
    cc 2.5
    TC 17.0
    TA 70
    CYA 50
    PH 7.2
    Thanks
    Charlie
    18,000 gal SWG, pebble tech, Jandy filter, Jandy Aquapure
    Flower Mound, Texas
    30,419
    Re: When to add salt when shocking
    Wait until the shock process is complete, then put in the salt. It'll dissolve right away and be ready for the SWG by the time you get ready to use it.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    I'd wait until everything is clear and you've done the final backwash of the filter. Why put in salt if you're just going to flush it out?
    Aug 2009
    Flower Mound/Texas
    41
    Thanks...hopefully I will be dine in a few days
    Charlie
    Charlie
    Flower Mound, Texas
