Results 1 to 8 of 8
Thread: Just got house with pool, but no manuals!!!
    My husband and I just bought a house built in the 70s. Really excited because it has a small bean-shaped in-ground pool in the backyard that is going to be perfect for floating around and getting out of the heat.
    However, when we stepped into the house after closing and found the owner tinkering with the pool equipment, we knew we were in trouble. Now our pool is sitting stagnant as he takes his time ordering the pump to get the pool running as it was when we signed the housing documents.
    So, besides being concerned about my pool sitting all this time not running (and not sure what I can do to keep things as nice as possible), we realized that all the old equipment that we inherited has NO MANUALS. We've never owned a pool and I don't even have a clue what I would need to do the basic maintenance like backwashing the filter or even programming the pump. We have inherited a pool that needs work in that the equipment is not on a slab or flat surface, but set in the yard. We know we are going to have to work on that.
    I guess my question(s) would be:
    1. Is there anything I can do besides skimming to keep the pool as nice as possible until the pump arrives?
    2. Does anyone know where I can find instructions for running pool equipment? Haven't found what I need here via searches. I know we have some sort of Intermedic (I think that's the brand) timer device. Other than that I just don't know any of this stuff.
    I appreciate all help. Have learned so much from this site and am really happy with my basic knowledge so far, but I need to know how to run this equipment and not sure where to go for this info.
    Thanks!
    April
    Feb 2008
    Los Gatos, CA
    128
    My pool also came with no manuals. I looked into the manufacturers' websites and found many manuals online via these websites.
    You might also want to consider paying a pool service to do an orientation session with you. You want to pay close attention to how to run and program the equipment and how to clean and maintain it. The chemistry you can easily get from these forums.
    You probably have an Intermatic timer.
    Good luck!
    Salinda
    owner of ~37,000 gallon plaster IG pool/spa combo. Intelliflo VS+ filter pump, 2 hp whisperflo spa jet pump, Jandy Aqualink RS-6 with iAqualink upgrade, The Pool Cleaner 4x suction cleaner, Clean & Clear Plus 520 cartridge filter, Zodiac Clearwater LM2-40 SWG, Sta-rite 400k heater, solar heat pads and coils, Solar-Breeze NX.
    Now would be a good time to start reading some of the articles in the Stickies section of this site, see the link in the sub-heading of each page or in my signature.
    I don't know what your arraignment with the seller is but it might be much better to fix things yourself right now and then try to bill him. His legal liability depends on details of your contract and the timing of events so check with your real estate agent or a lawyer. Leaving a pool sitting without a pump usually leads very quickly to algae, which can be dealt with without any permanent damage but is a pain.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi April and Welcome to TFP
    You're done SLAMing when:
    duh!
    Thank you so much! For someone who works in the web, I can't believe that wasn't my first thought to look for manuls online.
    Appreciate the link to the stickies as I will be poring over that for any other tidbits I need.
    This is a really great site, and I appreciate the instantaneous advice!
    -April
    Attached Files Attached Files
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    Re: duh!
    Quote Originally Posted by stockwellapril
    -April
    welcome to TFP. The DE filter sticky is awesome - if indeed you do have a DE filter.
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    Welcome!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    billyjoeraybob's Avatar
    Apr 2008
    SC Midlands
    50
    Welcome April! Most importantly don't freak out! I know right now it is intimidating. Get the equipment functioning(pump and filter). Get yourself a good drop based test kit. The TF-100 mentioned here is a wonderful kit. Also Duraleigh a member here sells it and is always available to give advice. Taylor makes a good one as well but I can't remember the number. The suggestion to get a local pool co to give you an oreintation is a good one. Remember if you have questions just ask. Someone here most likely will have an answer. Before you know it you will be on a float enjoying an adult beverage and loving life.
    Bill
    18' x 36' Freeform IG Gunite with 7' spa, Super Blue DiamondBrite, Pentair 1.5 hp circulation pump, Pentair 2.0 hp spa booster pump, Pentair Triton II Sand filter, Polaris 280 with booster pump, Pentair Intellichlor IC40 SWCG, Jandy Laars LX 250k btu NG heater, TF-100 test kit from http://www.tftestkits.com/
