Thread: TA Help!
    TA Help!
    Hello! Let me start by saying, I have the hth 6-way test kit from Wallie World. Could anyone please tell me, after getting the 25ml filled with my pool water and then adding the indicator liquid, when I add the drops of the titrant in the water, the water turned pink only after dropping 3 drops. Is this right or should I keep adding drops until it turns a truer red? The first time I did this, I think I added like 12 drops and it only got pinker. Want to test my pool in a minute and want to understand this first. A fast response would be well appreciated. Thanks so much!
    My Pool: 6000 gallon, vinyl Intex metal trim with the Krystal Clear Model 635T Filter Pump, HTH 6-way test from Walmart
    Re: TA Help!
    If it turns pink you add one more drop, if the color turns more pink you continue, but if the color remains the same you stop and don't count the final drop that didn't change the color any further.
    Re: TA Help!
    Oh, thank you very much. You wont believe how much you helped me on this!
    Thanks again!
