Thread: First pool first set of results
    May 2012
    Sturgis, Michigan
    20
    Salt is 3000 ppm
    FC-8.5
    cc-0
    TA-280 (I wiped the tip after everydrop just to make sure)
    PH-7.8
    CH-200
    CYA-below 20 added the amount intex recommended.
    So I know I need to get my TA and PH down ASAP. I have muriatic acid to do this but how much do I need to add? Also how long does it take to get an accurate reading for CYA? I added last night pool shock to get my FC up and started and HTH Stabilizer conditioner to the skimmer basket to bring up the CYA. Any other ideas or suggestions are appreciated as well. Thanks
    AG 18'X52" round Ultra frame Intex 8961 gallons with sand filter and SWG 1600 gph also have TF-100 Test kit
    Aug 2010
    Dallas, TX
    4,052
    Re: First pool first set of results
    http://poolcalculator.com/ will help you with your amounts.
    CYA can take a week to show.
    I suggest not using shock products once you get your CYA where you want it, as it most likely will continue adding CYA to the pool.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by heyblmyers
    Salt is 3000 ppm
    FC-8.5
    cc-0
    PH-7.8
    CH-200
    Plug your numbers into Pool Calculator and let it do the math for you. Target 7.3 as your new pH; with your TA it will jump back up fairly quickly. Expect to need a good amount - several gallons - of acid over the next month or so until TA stabilizes.
    CYA won't register for about a week.
    Butterfly's Avatar
    South Carolina
    10,045
    Since you have a SWCG, you should start the TA lowering process described in Pool School.
    Use the PoolCalculator.com to figure the muriatic acid dosees. Don't forget to put your TA in the calculator, as it will affect the calcs.
    The CYA can take up to a week to register on the test, so don't waste your reagents testing too early. However, after the CYA is dissolved, assume it is in the water and adjust your FC levels accordingly.
    You're done SLAMing when:
