Thread: Checking in with levels
    Nov 2011
    Lewiston Idaho
    76
    Hi All,
    Just checking in on my pool Chem levels.
    We are keeping the the following levels.
    FC 7ppm
    PH 7.5
    TA 120
    CH 250
    CYA 60
    CSI 0.05
    The CH was down to 220 so I added Hardness increaser raised it up to 250. I see in the pool school CH levels from 250-350 in one place and 220-350 in another. Not sure which way to go. Right now in the last 4 weeks we have had the PH creep from 7.5 to 7.8 I put in the recommended amount of MA and it dropped back to 7.5.
    From what I read the TA is a bit high, but with the PH pretty much staying where it is I think it is ok. Any opinions on that one?
    I am back on the road for 2 weeks again and did some basic maint while home. I added a solar cover and a timer for the pump and heater. I pulled the filters and cleaned them both. Everything seemed to running great. My son and wife are doing a great job keeping things sparkly.
    Thanks as usual!
    Phil
    18,000 gallon in-ground plaster pool. Sta-rite cartridge filter, Sta-Rite Max-E-Glas II pump 1 1/2hp motor, Caretaker pool cleaner, Teledyne LAARS series 2 ESC natural gas heater 250,000 BTU. Solar Pool cover, Intermatic Timer with heater switch. Two very happy kids!
    Re: Checking in with levels
    Your slightly high TA is causing your PH to rise. If that PH increase doesn't bother you then there is no rush on lowering TA.
    Other than that, things are looking good.
    Nov 2011
    Lewiston Idaho
    76
    Thanks Jason,
    I can live with 20-30 oz of MA every couple of weeks.
    So you think 250 is a good level for the CH? It is at the low side of the scale.
    Thanks
    Phil
    Aug 2010
    Dallas, TX
    4,052
    250 is fine.
    Nov 2011
    Lewiston Idaho
    76
    Thanks
