Thread: Filter sand excreted during rinse?
    Just doing my spring opening and I am seeing about a 1/2 cup filter sand come out of the blue waste hose whenever I do a 3 minute rinse, but none during a backwash or during filtration.
    Would this be a broken lateral, something else or just the need to gently clean the sand with a garden hose? (Just curious before I dig out 200lbs of sand to check the laterals)
    Thanks.
    Pool
    Vinyl 24 foot Above Ground Circular.
    50,000 Liters / 13500 Gallons.
    Filter
    Sta-Rite T-200BP-1 Sand Filter.
    200 pounds of sand, replaced May 2010.
    2.18 ft2 :: 44 USgpm :: 20 USg ::50 PSig
    Pump
    JWPAS5FC-2A3 (1-1/2hp)
    30,419
    Re: Filter sand excreted during rinse?
    Since it's only doing it on rinse, there is no need to suspect the laterals. It is very likely a bad spider gasket in the multiport valve. Pretty easy DIY once you get the right gasket.
    Turns out I was wrong. The water wasn't clear enough yet (was just in the opening process) to see the sand sitting on the bottom of the pool. Once I saw that the spider gasket was still good (thankfully, I have a Sta-Rite model that is now obsolete and would require new plumbing) I opened up the filter and found that 3 of my 8 laterals had come off. Not broken, just come off. The housing assembly that holds the laterals was coming apart, bottom separating from top, so those 3 laterals just slipped right off.
    This is my fix, I don't think there should be a problem with it. Does anyone know why this would not work? (I basically clamped around the halves and then cable-tied the rest of the laterals so that they won't come lose again.)
    Pool
    Filter
    Pump
    22,548
    That should work.
    By the way, you're not the first person this season that's reported the lateral holder coming apart.
