Results 1 to 9 of 9
Thread: I think I ruined the pool party...
    My chlorine level dipped down to 1ppm so before I left for work I turned on the stenner pump and set the timer for 2hrs.
    When I got home in the morning my chlorine level was 18ppm.
    I forgot that I had the pump on the highest setting which is 17 gallons over 24 hrs.
    Im using 12% chlorine.
    Anyway today we had a party planned - is there anything I can do to make the pool safe to swim in?
    I would think that 18% is way to high for swimmers.
    27' AGP, stenner pump, 30 gallon holding tank, 2hp two speed pump, cartridge filter, 12.5% liquid chlorine.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    Re: I think I ruined the pool party...
    What are your CYA levels?
    As long as your FC level is below shock level given your CYA level you will be fine. But you need to know what your CYA level is to figure that out.
    CYA is at 50.
    Butterfly's Avatar
    South Carolina
    10,045
    Shock level for CYA of 50 is FC 20. You are below that so have a good time!
    You're done SLAMing when:
    30,403
    CYA of 50 combined with FC of 18 is fine....go swimming.
    PS - it's not 18%, of course but 18ppm.....get back up there in Pool School after the party!!
    Sorry for the typos..
    Thanks for the help!!!
    22,542
    In fact you may have made it better. You won't have to worry about the FC level getting too low during the party.
    Mar 2007
    San Rafael, CA USA
    12,082
    People may notice some fresh bleach-like chlorine smell, but it still won't be as strong as in many indoor commercial/public pools that don't use any CYA.
