Thread: New to Site - Cloudy Water
    May 2012
    Bowling Green, KY
    38
    We recently purchased a home that has a very nice 30,000 gallon L-Shaped pool. I had it opened on May 6th. By using strips I have yet to get a FC reading above zero. The water is very cloudy - can barely see main drain cover in 10 foot end. I have ordered the TF 100 test kit after reading on this site but it has not arrived yet. The best test results I can post now are (from strips):
    ph - 7.2
    FC - 0
    TA - 80
    Stabalizer - 20
    I''m frustrated because I have had the pool company here several times. Phosphates were off the chart so he added a chemical that created a powder substance on the bottom of the pool - It was vacuumed out the next day. That dropped the phospahate level significantly but the water is cloudy. I have added several lbs of chlorine powder alonmg with the chlorine feeder, yet I still get a FC reading of zero.
    Any suggestions for now would be nice as I await the TF-100. Also, after the test arrives, how will I know how much of each chemical to puit into pool?
    30,000 gallon, IG, Vinyl, Sand Filter, Hayward Super Pump - 3450 RPM, 1.5 HP
    South Central Kentucky
    Re: New to Site - Cloudy Water
    Welcome to TFP!
    I would avoid phosphate remover, it is not required, makes the water cloudy, and is generally a pain and a waste of money. My phosphate level has been in the several thousands for years and I have never had a problem.
    You need to shock the pool. See the instructions in Pool School.
    May 2012
    Bowling Green, KY
    38
    I have read that secttion and I still do not understand how to determine how much bleach to put into pool - since my TF-100 hasn't arrived yet. Also, is it accepteble to now shift to bleach after using the powder chlorine? It stinks because I have $300 worth of Zap It on hand.
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    Ordering the TF100 is the best thing you could have done and you will soon be in charge of your pool.
    I suggest you try to maintain an FC of 10, which would be shock level for the CYA of 20.
    If you can find a source with better prices for liquid chlorine (about 12%), you should try that as you would be hauling half as many jugs.
    Let the PoolCalculator.Com figure the doses for you.
    Example: 30 K gallon pool, raising FC from zero to 10 = adding 4 gallons 3 quarts or 6.5 (96 oz) jugs of 6% bleach or,
    2 gallons 1 quart 3 cups or 2.4 (128 oz) jugs of 12% liquid chlorine
    No problem switching to bleach/liquid chlorine.
    You're done SLAMing when:
    May 2012
    Bowling Green, KY
    38
    Thank you for your help. I will post test results once the test kit arrives. For now, I'm off to purchase bleach!
