Thread: Plastic stairs in an Intex pool? Can it be done?
    Jul 2011
    Albuquerque, NM
    38
    Hi everyone. I have to update my siggy as we have graduated from at 12 ft intex metal frame to a 15 foot this year. As its a bit deeper (48 inch vs last years 36) we need a good way for our special needs daughter and son and aging grandma to get in and out safely. We are considering getting some of those plastic stairs that sink in the water with sand bags. Can these be used in an intex frame pool? If so any suggestions? Also how would you put a cover on then with the hand rails sticking up? We need the cover on,it helped so much last year when not in use.
    This forum has been awesome at helping last year. And the suggestion this year of getting the sand filter is excellent. We will be doing that!
    Thanks for the help!
    Jenn
    Jenn, From New Mexico
    8600 gal Intex 12x24x52 ultra rectangular pool, current filter: Sand Filter Pump with 1,600 gallon (6,056 L) per hour flow rate
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Re: Plastic stairs in an Intex pool? Can it be done?
    Yes they can be used and work quite well actually. We've got wedding cake steps in ours and absolutely love it. Work great as a underwater seat too. Not really sure about a cover though. You'd have to modify it with a slit to go around the rail.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Jan 2012
    Minnesota
    34
    Do you have any pics of the steps in your pool? Ty
    Above Ground Intex 18'X9'X54" Ultra frame rectangular Pool. Intex filter pump, Intex Krystal Clear Saltwater System. Solar Pool Cover.Eco Saver 20-Foot Solar Heating Panel System.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Quote Originally Posted by Sarahrip
    Here ya go
    And from farther
