Thread: Is CL loss by percentage?
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Hey:
    First opening with BBB, initial results (TF-100):
    CL-0
    pH-7.5
    TA-60
    CYA-40
    CH-100
    Water was very clear but there was a "dust" on the bottom so decided to shock. Added 11/2 gals 12.5%, added 4 lbs of baking soda.
    CL-15
    CC-0.5
    pH-7.5
    TA-90
    etc.
    Water is sparkling clear, everything seems well.
    OCLT-1.0, CC-0.5
    I'm just wondering about the speed that the CL fell. Normally, my CL loss never exceeds 4 ppm per day, but I was down from 15 to 6 in 12 hrs.
    Normal?
    Does CL dissipate by % as opposed to the same amount of points no matter what the initial reading is?
    Thank you.
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    Re: Is CL loss by percentage?
    If everything else remains the same, the amount of chlorine you lose is a percentage of your starting level. With CYA around 40 your chlorine loss is completely normal.
