Thread: Chlorine pucks (trichlor)
    Jul 2011
    Mesa Arizona
    190
    I'm sure this has probably been asked before but I haven't found where yet so I'll just ask again.
    Ideally, we would like to be able to add chlorine to our water without adding anything else. The pucks add CYA.
    Can't someone make a trichlor puck with no CYA, calcium or anything else that accumulates in the pool water????? Isn't there some kind of binder that will hold chlorine but nothing else that effects the water?
    Just curious as to why that can't be done? Is there a scientific reason or am I just stupid? lol.
    Mesa Arizona. Old school 26,000 gallon in ground plaster pool with sand filter built in 1984.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Chlorine pucks (trichlor)
    There are no chlorine pucks that dissolve slowly that do not introduce cya into the pool when dissolving.
    There are some calcium hypochlorite pucks I have heard about, but I think they require a special feeder since they tend to dissolve fast. They also introduce calcuim into the pool.
    JasonLion had a good post on this: http://www.troublefreepool.com/3-chl...12.html#p94102
    Jul 2011
    Mesa Arizona
    190
    Hey, thanks for the link. That explains things for me.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    No problem, I had the same question at one point.
