Thread: Base Plate For Stair Rail-Is Ther Such A Thing?
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    I was given a very nice handrail for my wide stairs going into my pool.
    Will I need to drill 2 holes about 3" in diameter into the concrete to install this or does anyone make a baseplate that would allow mw to drill 4 small holes and install threaded anchors for a base plate instead?
    Thanks
    18' X 36' Inground Pool 26,000 gallons. SuperMax 27mil/27mil Vinyl Liner-Installed Fall 2011
    Pentair Intellipro Programable Pump (Model 011018) // Pentair S8M 500 Cartridge Filter // Circupool RJ45 Salt Chlorinator
    2 Hayward Skimmers // 3 Returns // 2 Savi Melody Pool lights // TF-100 Test Kit.
    Mar 2009
    Huntsville, AL
    156
    Re: Base Plate For Stair Rail-Is Ther Such A Thing?
    There are some at the following link -- you will have to check the diameter of rail to see if any of these will fit.
    http://www.poolcenter.com/parts_deck...der_anchor.htm
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
