Thread: Clean Filter Pressure Increased from Last Year
    Sep 2007
    Gloucester County, NJ
    141
    We opened our pool this weekend. It started out very cloudy as I have a mesh safety cover and LOTS of silt had passed through. As of last night, I could start to see the bottom of the shallow end. My PH was through the roof and I am working to bring that down. I've backwashed twice so far. I've noticed, however, that the filter pressure after backwashing is about 4 lbs greater than it was last year. What might cause this?
    28,000 gallon gunite/white plaster with 30ft RBB and 2ft sheer descent, 100 sq ft thermaledge, 50sq ft spa w/ 6 jets
    2HP Jandy pump, 60sq ft Jandy DE filter, 400,000 BTU Jandy LX Nat Gas Heater, 2 Jandy color lights + Jandy color spa light, Jandy Aqualink RS6, Jandy AquaPure 1400
    Over time crud can accumulate on the grids/fingers of a DE filter, blocking portions of the filter. You can usually get back down to nearly the original pressure by soaking the grids/fingers in water with automatic dishwasher detergent overnight. Before doing that it is worth a quick double check that you don't have any valves in the wrong position, which could also increase the pressure.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    How long did you backwash? I've seen unexpected pressure drops after longer than normal backwash cycles, which tells me I wasn't backwashing enough. Another thing to check is that all of your return fittings are pointed at normal angles.
    The most likely culprit is the gauge itself.
    Mar 2008
    friendswood, tx
    32
    sounds like the filter screen or grid needs a more intensive cleaning..as noted in the sticky on DE maint postedy by 'waste'..
    2) Types –
    There are 2 different types of DE filters:
    The first uses ‘fingers’ (fabric wrapped hollow tubes, usually 100/ filter) to collect a layer of the DE on. This style is also known as a ‘bump’ filter because the DE can be ‘recharged’ via the use of a handle which moves the whole assembly up and down to expose new pathways in the DE coating without having to replace any DE (I’ll talk about ‘bumping” a filter in a minute.) (There are some ‘grid’ filters which have a handle on the top connected to a plastic plate which operate the same way)
    The newer models have a series of grids to collect the DE and either have a multiport valve or a ‘push/ pull’ valve (of which I will speak very little). These units allow you to ‘backwash’ most of the DE out when the filter needs to be cleaned. (* some localities do not allow wasted DE to be flushed into sewers or even onto your own property – in that case a ‘separator’ would need to be installed on the backwash line).
    3) Start - Up
    The fabric which holds the DE does very little to filter the water! As such, a DE filter needs to have a coating of DE on the grids/ fingers as soon as the pool is started up. Your installer or pool tech should do this for you the first time and give you a complete lesson on operating your pool (called ‘pool school’- it’s a lot of info all at once and it is very understandable that some of the info is forgotten by a pool owner). The amount of DE required by each filter is determined by the size of the filter – there should be a label on the filter identifying the size of the unit and how much DE it requires when completely clean. As said, KNOWING how much DE you are adding is key! Make sure to note what the pressure gauge reads when the unit is clean and freshly coated with the DE!!
    4) Maintenance
    Your filter should run anywhere from 8 psi to 20 psi with fresh DE put in it, depending on your pool and filter system. When the psi rises 8, it’s time to clean the used DE out of it. (when doing any filter work, turn off the pump
    Bump filters:
    1) open the air valve on the top of the unit for ~ 5 sec. and close (bumping with the unit full of water will harm the unit!)
    2) Slowly push the handle down and quickly raise it up 4 – 6 times.
    3) Now turn the pump back on and see if the psi went down, if it didn’t drop more than 2 psi, you need to dump the used DE.
    4) (if you need to dump the DE) – Open the drain outlet on the filter after doing steps 1 and 2 and run the pump for 20 seconds. Close the outlet and run the pump for a minute (don’t do this if you have an algae problem! The uncoated parts of the fingers will collect algae too quickly and clog), then repeat the procedure (make sure you open the air relief while the pump is running until water comes out of it)
    5) At this point, you have removed ~ 80% of the old/ used DE so only add 80% of the DE you would use in a new or fully clean filter!!
    Grid filters:
    1) Pretty much the same as bump, except you have a multiport which allows you to backwash the filter when the pressure rises 8 psi.
    2) (always!! Turn off the pump when changing multiport positions!!) Turn the multiport to ‘backwash’ and restart the pump, watch the view-glass or the end of the discharge hose to see when the backwashed water becomes ~ clear. When it is fairly clear, turn the multi to ‘rinse’ for 15 – 20 seconds and then back to ‘backwash’ until the water runs ~ clear again. Repeat the ‘rinse/ backwash’ until the water comes out clear when backwashing, add a short ‘rinse’ and the filter is about as clean as you’ll get it using the ‘backwash’ function.
    3) If the water in the pool is fairly clear, I’ll throw in a 1 min filter cycle and do the ‘backwash/ rinse’ cycle(s) again.
    4) At this point, you have removed ~ 80% of the old/ used DE so only add 80% of the DE you would use in a new or fully clean filter!!
    When bumping/ backwashing doesn’t work:
    Sometimes just ‘dumping’ the old De isn’t enough to get you back to proper filter performance – this can be caused by algae (or some other fine debris clogging the DE), or neglect (you didn’t clean the filter soon enough), or the grids/ fingers getting clogged up.
    At this point, you need to take the filter apart and manually hose them off (it’s a wet process – so be prepared to get ~ soaked). I recommend the manual hosing every year (I like doing it in the fall when the pool is being closed because, then you know the filter is ready for another season)
    If , when manually rinsing the grids, you notice that water is staying in the membrane for more than ~30 seconds, it’s time for a chemical cleaning!
    To chemically clean the grids/ nest:
    1) Have a bucket/ container large enough to hold the entire assembly
    2) #1 Add some TSP (tri-sodium-phosphate) to the water or some electric dishwasher detergent to the water and soak the grids for 3 hours – this will ‘de-grease’ the membranes and is the first step in cleaning them, rinse with hose and get ready for step 3.
    3) Dump the container, refill with water and add muriatic acid to the water so that you have a 10:1 water: acid mixture and soak the grids for another 3 hours, this will clean any calcium off of the grids. Rinse grids again and reinstall them in the filter.
    4) Now, run pump and bleed off the air from the filter and add 100% of the DE the filter calls for.
    Mar 2008
    friendswood, tx
    32
    another thread..similar problem..
    http://www.troublefreepool.com/viewtopic.php?t=4382
