Thread: How to attach backwash hose?
    How in the world do you attach the hose to the DE filter when you backwash? I'm doing the opening cleaning of my new (to me) pool, and am mystified as to how to attach the backwash hose to the filter. I've tried Google, but couldn't find anything helpful. All the web pages said to "attach the hose." Yes, I KNOW that, but HOW? The hose seems so much bigger in diameter than the pipe it attaches to, I'm at a loss. Any help is greatly appreciated.
    Kelleyaynn
    21,000 gallon (+ or -) in-ground plaster pool with Nautilus DE filter, 1 hp pump, and Zodiac G4 automatic vacuum.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Re: How to attach backwash hose?
    An adjustble screw hose clamp like on a radiator hose.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Woody nailed it. And when you tighten the hose clamp, tighten it good. Then roll the hose out and get rid of any kinks or twists. Water will come out so fast it will blow the hose if there's a kink. Ask me how I know...
    Well, this makes sense. So tomorrow I'm off to the hardware store before I do any backwashing. Previous owners left nothing that would be helpful.
    Kelleyaynn
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Just make sure the backwash hose is a large enough diameter to fit over the outlet on the filter. The Intex outlet is larger than the typical backwash hose iirc.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
