Results 1 to 9 of 9
Thread: Another Pool Skim Review
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Well, I installed my PoolSkim today, and after a full day of use, I am overall happy with the device.
    A poolskim is an aftermarket pool cleaning accessory that claims to be an effective skimmer for the pool, and an improvement over traditional skimmers.
    We have a large german shepherd mix that absolutely loves our pool. Unfortunately he is a super-shedding dog. For the pas few months since he moved in my wife has constantly been unhappy with the amount of hair floating on the surface of the pool. One day in an hour of skimming I got a double handful of hair. I dont know how he grows it so fast.
    So after searching and reading, I decided to order the poolskim and give it a try.
    It was around $100, and arrived promptly. Opening the box all sorts of parts and pieces spilled out, it was pretty intimidating.
    After sorting the parts and laying them out on the deck, it turned out to be a snap to install, didnt have to cut any pipe or anything. I just removed an eyeball, screwed on the supplied adapter and slip-fitted the pipe and fittings together and connected the poolskim. You may want to turn your pump off while you do this, it certainly is easier not to have to fight the current coming out of the eyeball fitting while you assemble it.
    It immediately developed a venturi suction and went to work. To be honest I was pretty skeptical of it, but decided to give it a few hours and see how it did.
    Oh My Gosh. It was extremely effective and within two hours had removed every piece of hair from the surface of the pool (about 600 sq ft). I was stunned. The sock had a big ball of hair trapped at the end that built up over time. Very effective.
    My only negatives about it are cosmetic. Functionally it works GREAT. Our pool is in neutrals, tans and greys, and the white and blue poolskim just does not visually "go" with the pool at all. I wish they sold it in different colors.
    Other than that I could not be happier with the device, and wanted to post a good review so others could benefit in their decision making.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    22,550
    Re: Another Pool Skim Review
    I've been on the fence about one. Looks like I'll be falling off in the near future.
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    Go For it it.. you wont regret it--I have had mine a year now.. Only thing I can say--the bag is not that good of quality... I did find some filter bags from Mcmaster Carr that is 100 micron and they work great as replacement for it.
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Yeah on the filter sock I was thinking some panty hose would be better.
    Montreal Canada
    326
    I received mine and installed it last week in my 18ft above ground.
    The thing is awesome, works exactly as described. And it's very solid, it survived a whole weekend of pool play with my 4 yr old. It even managed to trap Ariel the Mermaid without complaining.
    Part of my late Sunday was just sitting poolside watching leaves fall in the pool, floating round and round and eventually being absorbed by The Unit. Very zen.
    But I can't decide whether to create a clockwise or counterclockwise flow. As it stands now it's a clockwise flow, and the blue bag is inches from the skimmer.
    Should I point it opposite to the skimmer?
    Every once in a while something works as advertised, or better. This happens to be one of them. Would be lost without due to many trees with flowers, whirlybirds and cherries.
    Jul 2007
    Northern NJ
    299
    Ditto! I have had mine for 3 seasons, this is the start of the 4th. It was WELL WORTH the $100. I NEVER have to skim and I have a ton of trees.
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    May 2012
    North of Charlotte, NC
    312
    Has anyone experienced any major loss of pool circulation using this ? Especially if you only have 2 return jets in opposite corners ? Or has the circulation remained the same as before removing the eyeball ??
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    Try turning the mesh bag inside out and then attaching it to the POOLSKIM. This makes cleaning and rinsing the bag much easier since you are working with the ‘smooth’ side collecting the debris. If your bag has excess strands of netting, use a pair of scissors to trim them off.
    Has anyone experienced any major loss of pool circulation using this?
    Circulation does slow a bit since the opening of the discharge side of the POOLSKIM is
    rather large. It still pushes quite a bit of water but lacks the ‘force’ an eyeball can provide. You lose the ability to direct the flow up and down, unless you devise some type of diverter.
    It is a great product that performs as advertised.
    Regards,
    -Gary
    12,000 gallon, tile finish, in-ground pool with spill over spa.
    Pump - Sta-Rite 1.5 HP
    Filter - Hayward Star-Clear C-1200
    SWG - AutoPilot Soft Touch
    Pool Skim
    Zodiac MX8
    BBB since 11/2008
    South Florida
