Thread: Ph good, TA low, should I add Borates now?
    May 2009
    Marion, Ohio
    32
    Just installed new liner and all new water. My readings:
    Cc 0
    FC 3
    Ph. 7.5
    TA 30
    Cya - added yesterday to bring to 30
    Which do I do first? Add borates or baking soda? Do I lower PH first or test after ans see if I need to lower? Thanks for the help - this place is great!
    10,000 gallon in ground vinyl
    10,000 gallon inground vinyl FOXX pool - built in 1999. Hayward sand filter. 3/4 HP 2-speed pump with timer. Hayward Aquarite SWG t-3 cell. Love the BBB method - pool has never looked better!
    30,419
    Re: Ph good, TA low, should I add Borates now?
    Bring your TA up to around 80-90 or so using Baking Soda.
    I would also suggest increasing CYA to about 50ppm.
    Leave your pH alone
    Skip adding any borates for now
    May 2009
    Marion, Ohio
    32
    Thanks! It's hotter than a firecracker here in Ohio!
    Throwing in the baking soda now!
