Thread: Can't Read TA
    Can't Read TA
    My daughter ask me to come out and take reading on her pool as she could not get it to clear up. 25,000 gal IG vinyl with sand filter. I have an FT-100 test kit. CYA 60, FC .5, PH could not be read as color was yellow way below 6.8 on the test tube. TA added 2 drops of R-0007 than 5 drops of R-0008 and the test water turned red not green. Where do I go from here?
    Mike
    22,551
    Re: Can't Read TA
    That means you have zero TA and a pH of 4.5. You need to get it up immediately and then retest and adjust the pH.
    Mar 2007
    Virginia Beach
    272
    Re: Can't Read TA
    I just did a post with the exact same issue. What should you fix? TA or PH? IE Backing soda or Mule Team 20?
    6000 gal inground fiberglass
    1.5hp pump / sand filter
    Liquidator
    30,426
    Re: Can't Read TA
    Bring the TA up first to around 50, then pH up to 7.2, then readjust TA if necessary.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Can't Read TA
    Use baking soda to raise the TA and use borax to raise the pH.
    You're done SLAMing when:
    Re: Can't Read TA
    Thanks, I will have her start by adding baking soda.
    Mike
