Thread: Should I lower pH?
    tlwilson's Avatar
    Aug 2010
    Nebraska
    50
    Should I lower pH?
    I add MA at least twice a week because my pH keeps going up and hit 8.0 once. It is 7.8 today. TA is 110, so I don't want to give it a big hit of MA to lower pH. Two days ago I put in 32 oz MA according to the Pool Calculator. I hate it that I am lowering the pH all the time and my concern is if I let it sit at 7.8, it will sure go to 8.0 or above in a short time. Is this normal?
    FC 2.6 (will add chlorine tonight after the sun goes behind the house)
    CC 0.0
    pH 7.8
    TA 110
    CYA 45
    Water is clear and sparkly and 84 degrees.
    24,000 Gal In Ground pool
    Vinyl Liner; Sand Filter
    Pentair Intelliflo pump
    Pentair IntelliChlor IC40 SWG
    Raypak Gas Heater
    30,419
    Re: Should I lower pH?
    I suggest you lower the TA using the method in Pool School. Once your TA gets around 80, aerate back up to get your pH around 7.2 - 7.4 and then see if it will be more stable.
    tlwilson's Avatar
    Aug 2010
    Nebraska
    50
    There is a lot of wind here the last couple of weeks with frequent, high gusts that ripple the water. Is that contributing to the pH increase?
    Raypak Gas Heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Quote Originally Posted by tlwilson
    Almost certainly.
    tlwilson's Avatar
    Aug 2010
    Nebraska
    50
    You folks are the greatest! Such prompt, knowledgeable responses! I appreciate your help so much.
    Raypak Gas Heater
