Thread: Am I there yet?
    Am I there yet?
    Here we go
    TA= 80ppm
    CH= 60 ppm
    pH = 7.4
    CYA= ~30 or a little lower
    CC = 0
    FC = 3.5
    I'm still working on getting the CYA up there (to 40). I read in pool school with a vinyl liner in an AG pool I don't need to worry about CH is that true? My SI is .9 which appears to be high.
    One other question, how long should I run the pump, I remember checking out a calculator for that last season but I never was able to figure it out based on the info on my pump (bought everything 2nd hand). Thanks!
    AG-Aqua Leader Jazz, 24'x52" Round, 14,633 gal, Hayward Power Flo LX 1.0 HP Pump, Clearwater II Cartridge filter
    Re: Am I there yet?
    Correct, no need to add calcium. Your SI is fairly negative, -0.8 or -0.9, which is fine with vinyl. If it was actually high that could be a problem.
    I suspect you can run the pump for about 4 hours a day and be fine, but it is best to start higher and work you way down. I recommend starting at 8 hours a day. Get a feel for what that is like. Then turn it down one hour shorter each week until the water loses it's sparkle, then turn it back up an extra hour a day and use that.
    Re: Am I there yet?
    Thanks, this is the best pool website ever! I've learned a lot and it is true.....GET A GOOD TEST KIT!
