Results 1 to 10 of 10
Thread: Considering using Borax for the 1'st time
    May 2011
    Clifton, NJ
    14
    I am going on my second season with my pool and have learned a lot from reading the Pool School area.
    My question or concern is I am considering trying Borax this year and was just concerned how to approach getting started.
    My levels are:
    FC - 8
    pH - 7.8
    TA - 70
    CH - 200
    CYA - 0
    Salt level - 2800
    I read the basics and input the numbers into the Pool Calculator and come up with about 17 boxes of Borax and 4 Gallons of muriatic acid.
    Is there anything I am overlooking, or can I just go ahead and do it.
    My pool is is direct sunlight throught the day so I understand the importance of the stabilizer. Before I just add stabilizer I figured now would be the time to decide on trying Borax
    Thank you
    22K gal, DE, IG Vinyl, Hayward Super Pump 1 1/2 HP@50 GPM, SWG - Gold Line Aqua Rite AQR w/ T-15 Cell.
    Re: Considering using Borax for the 1'st time
    Adding stabilizer is far more important than anything to do with borates.
    Borates are considered optional, everything works fine without them, just better with. If you want to add borates, then great go for it. But don't let anything get in the way of adding CYA.
    May 2011
    Clifton, NJ
    14
    Thank you I will
    Sep 2009
    Greentown, IN
    914
    I've been considering adding Borates as well, but like they said, your cya is first order of importance... You can add borates at any time. I bought some last year thinking I would add it, but haven't yet. I think the benefits sound great, just hard to add another chemical to the pool... which I know is already far safer than most of the ones around.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    May 2011
    Clifton, NJ
    14
    I just added the CYA, going to check the levels thru out the week and then go thru with it. I cannot thank the members enough for the wealth of knowledge on this website.
    For a first time pool owner, this website makes us look like pros. My pool water is very clean and sparkly. When I have guests over the first thing they say is " your water is so clear".
    I will keep you posted.
    Kevin
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Quote Originally Posted by mystar60
    ... My pool water is very clean and sparkly. When I have guests over the first thing they say is " your water is so clear".
    Ain't that a great feeling?
    I am afraid I have to tell you that you've come down with a condition known as sparklypoolitis. It's real - use the search box, you'll see we have outbreaks quite a bit here.
    Aug 2010
    Dallas, TX
    4,052
    Kevin
    We had some friends over yesterday who had never seen our pool. The first thing out of their mouths was "Wow, your water is really clear, who takes care of it for you?"
    May 2011
    Clifton, NJ
    14
    Here is what it looked like today.
    May 2011
    Coral Springs, FL (near Ft. Lauderdale)
    93
    Here's a link to the main thread about borates which will probably answer all of your questions and perhaps overload you with information: so-you-want-to-add-borates-to-your-pool-why-and-how-t4921.html
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter and Hayward Navigator V-Flex
    Jandy AquaPure 1400, Laars LX400 propane heater w/120 gal above-ground tank
    Jandy VS FloPro 2.7 HP Pump VSFHP270JEP; FlowVis FV-C Flow Meter
    Jandy iAquaLink and OneTouch controller w/PDA remotes; JVA for draining pool
    May 2011
    Clifton, NJ
    14
    Thanks, I did read that.
    With all the rain hear in the north east I have yet to try it. Actually I have to drain some water, it's almost over the scimmer.
