Thread: what should the Pressure be for sand filter.
    Oct 2010
    michigan
    284
    15,000 gallon pool/spa with heater
    sta rite 1.5 hp pump, phk2ra6f-103L
    sta rite sand filter, 350lbs sand, cristal-flo 2, 145363
    Multi valve system because of the spa
    starting pressure 20psi? is that about right/normal?
    so I let it get upto 30psi before back washing? seems kinda high, but thats why i'm here asking cause you guys are the experts.
    thanks
    steve
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Re: what should the Pressure be for sand filter.
    Every pool is different. We can't tell you what is normal for your pool.
    Clean the filter when the pressure goes up 25% over the starting pressure, i.e. if the starting pressure is 20, then clean when it gets to 25.
