Thread: How long to wait to retest pH?
    How long after adding muriatic acid should you wait before you retest the pH? My reading was probably over 8.2, so I expect I will need to add more to truly bring it down to the correct level.
    Thanks.
    Kelley
    Kelleyaynn
    21,000 gallon (+ or -) in-ground plaster pool with Nautilus DE filter, 1 hp pump, and Zodiac G4 automatic vacuum.
    30,403
    Re: How long to wait to retest pH?
    Pump running...usually 30 minutes to an hour
    Thanks.
    Kelleyaynn
