Thread: Green Swamp Back Want a Sparkling Oasis
    I am not new to having a pool, but this is the first year I have tried to get it completely up and running by myself.
    Pool type: in ground, vinyl liner
    Shape: rectangle
    Filter: DE
    pump size: I think it's 1.5 HP?
    PH 8.2 or higher? using test kit but 8.4 or higher using test strip
    TA: 140 with test kit but 180 with test strip
    FC: .5- 1.0 with kit, .5 with test strip
    TC: 1-2 with kit, .5 with test strip
    CH: 110
    CYA 30-40
    I had algae (lots of it) when took cover off. So much that I ended up going through the chlorine shock process and then had to vacuum to waste to get most of the debris out of the pool. Now, the readings posted are current from this morning.
    But, the water is still very milky or cloudy. It's gotten better every time I vacuum to waste but that is taking forever since I then have to use a garden hose to put water back in.
    Filter has been completely torn down, cleaned and put back together once. Backwashed frequently even though the pressure really hasn't gone up in between the backwashing.
    So, now what? Should I try to adjust the PH down? Decrease the TA? Which do I do first?
    Please help. I've been at this for almost a month and still can't get in the pool. :{
    Feb 2012
    Stowe, VT
    59
    Re: Green Swamp Back Want a Sparkling Oasis
    Have you passed the OCLT?
    pool-school/overnight_fc_test
    You'll want to make sure the algae is dead. Otherwise you'll have to start over.
    69,000 Gal gunite indoor IG pool.
    5 HP Emerson - Pentair Triton II Commercial TR140c Sand Filter x2
    5,000 Gal gunite outdoor IG hot tub
    2 HP Sta-Rite - Pentair Triton II Commercial TR140c Sand Filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    It doesn't look like you've ever gotten started GOOD.........because FC is much too low. Lower PH to mid 7 range first. See the shock level you must MAINTAIN FC at per the CYA/chlorine chart in pool school. Don't worry about TA right now. Hang in there!
    Thanks - yes I think I passed the OCLT....at least from what was posted, I went through all the steps and had the correct end result. I'll try lowering the PH to see if that helps.
    Thanks again!
    Sep 2009
    Greentown, IN
    914
    Yes, you need to get your ph in range and then hold your shock value overnight, have clear water and CC at .5 or less before you are done shocking. Sounds like you're working towards it, but have a bit to go.
    Reminder, during the shock process when your have high levels of FC you ph will show out of range... don't mess with it. The ph test is not accurate when you are at shock levels.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    As Suziqzer said, the first priority is to get your PH down and FC level up. You should never allow the PH to get that high, or the FC level to get that low.
    There is no need to backwash the filter unless the pressure goes up. We recommend backwashing or cleaning the filter when the pressure goes up 25% from the starting pressure.
