Thread: pH balancing question from the newbie
    I have a 12x3 above ground pool. I tested the pH and added the pH minus stuff (2 oz as indicated on the lable) ... can you tell I'm a newbie yet? Retested after 3 hours and nothing has changed. I don't want to tank my pH too low by adding more too soon. Do I wait and then retest again? How long do I wait before adding more?
    After the pH is balanced, then add chlorine? Is that correct?
    Thanks for answering my silly questions!
    I have a Hayward vari-flo xl-valve. Hp 1.5 Model SM-1700t. Sand filter.
    I believe I have a 24" above ground round pool. Liner has fish on top and a ocean scene on bottom.
    We live in clarksville, Tn. The pool is in full sun.
    30,419
    Re: pH balancing question from the newbie
    What is your current pH?
    7.8... sorry. Forgot to post that.
    30,419
    You are fine where it is. Acceptable range is from 7.2 - 7.8.
    That said, if you would still like to lower it adding 2 oz in multiple steps and waiting 30-60 minutes should bring it down lower for you. You won't go too low if you test after each addition.
    (2 additions should bring it to about 7.4)
