Thread: Please help identifying liner
    Was getting ready to prep my pool for this season and as I removed the cover, I noticed that I only had about half a foot of water left on the bottom. Looks like I have a big enough leak somewhere towards the bottom. I'm not sure how long the water's been at that level, but I'm pretty sure the liner is shot and needs to be replaced.
    Problem is, I'm not exactly sure what kind of liner this is, as it doesn't look like the kinds that the guides show you for overlap, beaded, or unibeaded. Further, I measured the height from top of the liner to the bottom of the pool at about 2 feet from the edge and it's showing up around 49 inches (shouldn't it be 48 or 52?)
    Here are some pictures that I thought might help to identify - I'd appreciate any info that anyone might be able to provide.
    Thanks!
    15x24 Vinyl AG
    1.5 HP Hayward PowerFlo Matrix Pump
    Hayward EC50AC DE Filter
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Please help identifying liner
    That liner can have many names based on who is selling it. There is usually an ID tag on the back side of the liner somewhere. Regardless, 6 inches of water in the bottom of the pool should be enough to hold everything in place. I'd refill and check for a leak or have someone check for you.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Thanks for the info - I'll give the local pool place a call to see if they can identify the leak.
    Incidentally, is this a beaded liner? Also, is it likely to be a 48" or a 52", based on my measurements 2 feet out at 49"?
    15x24 Vinyl AG
