Thread: Cyanuric test
    Cyanuric test
    So I finally got a K-2006 kit and I was wondering how to interpret the CYA test. Should the black dot entirely disappear Thanks.
    AG-Aqua Leader Jazz, 24'x52" Round, 14,633 gal, Hayward Power Flo LX 1.0 HP Pump, Clearwater II Cartridge filter
    Re: Cyanuric test
    Yes, the black dot should completely and totally disappear, as if it was never there, even after you stare at it for several seconds. The test is designed to be done in bright light, ideally direct sunlight with the view tube shaded by your body.
    Re: Cyanuric test
    Thanks. Also when I add the DPD powder it takes quite awhile to dissolve, if it's not completely dissolved will that influence the results of the chlorine test?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Cyanuric test
    Are you swirling it around? I on occassion, crush the larger crystals in the jar and it seems to work better too.
    Re: Cyanuric test
    Yes, I swirl and stir.
    30,432
    Re: Cyanuric test
    It is irrelevant that the powder be completely dissolved. There is almost always some powder left in the solution and it has no effect on the test.
