Thread: Broken pump to filter connector
    Western Pennsylvania
    151
    Had an issue this morning and i thought i would share my solution.
    I had a leaking connector between the pump and filter was leaking, while removing it the connector broke leaving the threaded piece inside the impeller housing.
    I took an old connector that was a diameter that could fit inside the threaded piece and i put a screw threw the old connector so that about 1/8 inch was protruding through the other side, then i hammered that inside the threaded piece and it gripped enough for me to unscrew it.
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
    22,539
    Re: Broken pump to filter connector
    May 2012
    San Jose, CA
    141
    Nice... I suppose you could add more screws to get more bite if needed.
    24k gal 16x38, spa 7x6, Colorscape Caribbean Blue plaster, Pentair Intelliflow, Hayward jacuzzi air pump, Pentair 520 filter, Raypak 336k cu-ni heater, Aquabot Turbo T... pool remodel finished 8/2012.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    That's certainly a creative and imaginative solution. Thanks for sharing that.
