Results 1 to 11 of 11
Thread: What next
    What next
    16 x 32, 19,000 gallon pool. I am using trichlor and shocking with non-chlorine shock. Pool is clear, pump is running well. Numbers are within range on Ph, Alk and Stabilizer. Chlorine is not registering. Thought it was the test strips, replaced and still came up with the same results. I have never had this problem before. What should my next course of action be? I have never taken a sample to the local Leslies thinking that the results will always be skewed towards their liking. Switched back, last year, to trichlor after a couple years of using Liquid chlorine. It was cheaper and it seemed more stable and reliable. I started using the non-chlorine shock last year also. Thought it complimented the trichlor well. Do I need to initially shock with chlorine (liquid or otherwise) to get things going?
    Re: What next
    Welcome to TFP!
    It would be a huge help if you could post your test results. Saying "in range" really doesn't tell us anything.
    There isn't any point in using non-chlorine shock. It costs more and doesn't do anything better than chlorine does.
    Chances are you have not been shocking properly. I suggest your read the article on how to shock your pool in Pool School.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    Re: What next
    Hi, welcome to TFP! In order to help you figure out what is happening in your pool, we need to see a complete set of test results. Our ideal range for chemical values and the standard pool industry range of acceptable chemical values differ. Also the range of test values within the normal range can make a difference in what we recommend as well. Take a sample to a pool store and have it tested and post the results here. If they tell you to buy anything just say you have some at home. The test strips will not give us the results we need in order to help you.
    Love TFP? Become a
    TFP Supporter!
    Re: What next
    Test results
    TC 0
    FC 0
    pH 7.6
    Total alk 120
    Calcium 50
    Stab 40
    Re: What next
    You need to shock the pool with chlorine. With Stabilizer/CYA at 40, shock level is 16. Follow the instructions in pool school on how to shock your pool. Which very briefly mean test the FC level, add enough chlorine to raise FC to 16, wait an hour, and repeat.
    Re: What next
    After shocking with about 2.5 gal liquid chlorine, got a reading of 10 for FC. Measured an hour later, got same reading. The second hour I measured I was down to zero again. Bought some conditioner but have yet to add to pool. Will raising the cya to around 60 keep my levels stable after my next shocking?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: What next
    You need a FAS-DPD test which is included in either the Taylor K-2006 or the TFTestkits TF-100 test kits (Taylor also sells the FAS-DPD as a stand alone kit, but don't know the number) in order to accurately measure your chlorine level while shocking. Raising your CYA level now will make it harder to shock and fix your problem.
    22,553
    Re: What next
    Tftestkits also sells a standalone FAS-DPD kit.
    I wouldn't raise the CYA until you're done shocking.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,101
    Re: What next
    Quote Originally Posted by macabs1
    Raising your CYA level at all would be a bad idea. It's always' a good idea to keep it as low as you can. A level of 40 is a GREAT place to start. If something was taking 10PPM of your FC in two hours....there's a good chance you've got some stuff growing in your pool.
    What does your water look like? Photo's will help.
    Re: What next
    The water is crystal clear.
    Re: What next
    After raising my cya, it is now dark brown on my test strips, I was able to hold my FC levels overnight.
