Thread: First test after refilling pool
    Mar 2008
    Los Angeles, Ca
    222
    A couple of weeks ago, I decided to empty and clean my pool. It's fiberglass, so I high pressure washed it when it was empty.
    I also just got a tfp test kit and a magnetic stirrer, and took my first test today this morning.
    date 11-Apr
    fc ppm 1
    cc ppm 0.5
    tc 1.5
    ph 7.2
    ta 90
    ch 80
    cya 0
    temp 84
    fc was better yesterday, but the kids were in the pool all afternoon, and the cover was off. I added some Cl after taking this test.
    I am not worried about ch since its a fiberglass pool, and I expect the ch to slowly rise.
    I put in a little CYA on Thurs, but obviously not enough yet. I also know you are supposed to wait a week until the CYA test, but I did not put very much in yet. I have a sock with a few lbs of stabilizer in the skimmer right now.
    BTW, the magnetic stirrer is very cool, makes it easy to run these tests.
    Randy
    25,000 gal fiberglass pool, Raypak 200k BTU H200FDN gas heater, Pentair CCP520 520 sq ft Cart filter, Max-Flo VS2303VSP pump. iWave wireless remote,
    seperate spa, with own pump, cartridge filter, Hayward H200FDN heater
    Your numbers look good!
    Mar 2008
    Los Angeles, Ca
    222
    Thanks. We'll see what they look like next weekend,when I measure the CYA again.
    Randy
    Mar 2008
    Los Angeles, Ca
    222
    New numbers from this morning
    I measured the spa too. CYA might be a little below 20, tube was full, and I could see a very faint outline of the dot.
    pool
    date 20-Apr
    fc ppm 1.5
    cc ppm 0.5
    tc 2
    ph 7.3
    ta 90
    ch 80
    cya 20
    temp 73
    spa
    date 20-Apr
    fc ppm 5.5
    cc ppm 0.5
    tc 6
    ph 7.6
    ta 80
    ch 90
    cya 30
    temp 70
    Sep 2007
    Toronto
    106
    I thought with a fiberglass pool you should not empty the water, as ground pressure may cause it to cave in, or hydrostatic pressure may cause it to pop up?
    OH TWINS
    San Juan 8500 gal Fiberglass Pool, Sta-Rite Max-E 1 HP pump, Star-Rite System 3 Cartridge Filter 300 sq. ft,
    Sta-Rite Max-E 200,000 BTU gas heater, Aqua Logic SWG with P-4 panel. Goldline wireless remote control,
    3 Jandy Neverlube Valves with Goldline motorized control, iRobot Verro 500 pool cleaner
    5 Poolstar 1000 LED Lights, LED strip light at waterfall, Prozone Ozonator PZ7 with degasser column,
    Jandy Auto Waterfill, Aquamatic motorized pool cover, Poolbuster Max CC handheld vacuum.
    True, it is best not to empty a fiberglass pool. You can often get away with it, but there is always some risk of significant damage.
