Thread: AC water (possibly distilled) into pool
    Apr 2011
    Houston, TX, USA
    105
    Hey guys I was wondering if there are any adverse effects if I connect my AC unit output into the pool. AC dumps about 6 gallons of possibly distilled water that is more acidic than pool water.
    That's about as much water that I lose to evaporation.
    14500 gallon plaster pool (replastered in May 2009) : 32ft.L x 4ft.D x 14ft.W
    Pentair FNS Plus 48 sqft DE filter
    Polaris 280 at 2hrs per day (retired now) & Aquabot T-Jet Turbo used as needed
    Circupool RJ30 SWG set at 80% output & Pentair SuperFlo 1hp 2speed running 6-8 hrs/day in the summer
    Re: AC water (possibly distilled) into pool
    Usually that is fine. Occasionally, especially with lower quality AC units, the water will bring along some metals dissolved into the water from corrosion that can cause staining.
    Apr 2011
    Houston, TX, USA
    105
    Thanks Jason. My AC unit is only two years old
    Sep 2009
    Greentown, IN
    914
    You could collect the water coming from it and have it tested for metals to be sure... I think I would. Not a large quantity on a daily basis, but might be enough to cause a problem over time if there were some metals there.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Just to clarify, that is not distilled water but condensation and it will contain whatever impurities it may have picked up from the environment. I'm not saying you shouldn't use it, I have no opinion on that, just know it is far different from distilled water.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
    Apr 2011
    Houston, TX, USA
    105
    thanks guys, that's solid advice.
    I am not planning on swimming in the pool when this is happening.
