Results 1 to 10 of 10
Thread: Pool remodel
    May 2012
    Vernon Texas
    6
    Pool remodel
    Preparing pool for paint. will lime away work to remove scum from tile?
    30,000 gal. Igp, gunite, Indoor pool
    22,548
    Re: Pool remodel
    You absolutely shouldn't paint that pool! Why do you want to paint it?
    That looks like scale on the tiles and if it is, diluted muriatic acid will take it off.
    May 2012
    Vernon Texas
    6
    Re: Pool remodel
    It already has had an acid wash and scum has not come off. The paint has already been bought so it is getting painted.
    Mar 2010
    Spring, TX
    1,082
    Re: Pool remodel
    From what I have read on here, painting will actually cause more problems than help. It is a cheaper alternative yes, but when it starts to throw off your water balance due to peeling it may make you think. Remember hindsight always 20/20. I would listen to the people here and try to return the paint.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    22,548
    Re: Pool remodel
    Try a Magic Eraser and let us know if it works on a small place.
    May 2012
    Vernon Texas
    6
    Re: Pool remodel
    Here is what i tried so far Lime away, sos pads, kaboom. All worked about the same, not very well with a lot of elbow brease. Going to try a stronger solution of muratic tomorrow and elbow grease. Thanks for all comments.
    Jan 2011
    153
    Re: Pool remodel
    Do not paint, all you are doing is causing yourself issues with in a year and a huge expense to fix it down the road. The white line is calcium and is almost impossible to remove and will be back within 6 months.. Some company's offer a bead blasting to remove calcium.
    Western Pennsylvania
    151
    Re: Pool remodel
    The issue with painting it is that every 5-6 years you will need to remove the paint and start again.
    you may also get a lot of paint flaking off long before that
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
    Aug 2011
    Metro Atlanta, Georgia
    161
    Re: Pool remodel
    Quote Originally Posted by Eddie
    I have never used this, but it looks promising http://www.youtube.com/watch?v=qVuSEqkAToA maybe someone else will comment, but it is just a circular pumice stone. I believe they are carried at a national chain PS and may be in stock locally.
    My cement pond is a 36K gunite 20X40 built in mid 1960s, Hayward S244S filter, Aquarite SWCG, Jandy 1.5HP 2sp, TF-Test kit and Nitro Wall Climber
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Re: Pool remodel
    Any updates? I am curious to see if you painted.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
