Thread: Accurate salt test needed.
    May 2012
    South Florida
    36
    Jandy was out replacing sensor in new unit. They asked me if the unit was calibrated as they did not bring their calibrator. So, if the unit needs to be calibrated what is the most accurate testing method for home use. Right now the unit reads 3.7g/l or 3700 ppm(mg/l). Aquacheck test strips read 3070ppm.
    IG ~14,000 Gal
    Pentair clean n clear Cartridge 100g/
    SWG Aquapure 1400
    Hayward XL Cleaner
    Premix Marbletite Freestone series
    1.5Hp 2 speed
    TF-100
    Re: Accurate salt test needed.
    The Taylor salt test is the best available for home use, but even that is +-400.
    May 2012
    South Florida
    36
    Thanks. I'll order one right away.
    IG ~14,000 Gal
    SWG Aquapure 1400
    Hayward XL Cleaner
    1.5Hp 2 speed
    TF-100
    May 2012
    South Florida
    36
    Received Taylor salt .... Thanks
    Performed the following salt tests 3x
    pH 7.5
    FC 15 (just finished shocking pool)
    CC 0
    TA 70
    CYA 80
    CH 320
    Temp 93
    Aquacheck
    3330
    3330
    3330
    Taylor
    4200
    4200
    4400
    Aqapure sensor reads 3700
    So, what is the real salinity? Jandy was out replacing sensor and did not have calibrator. I told them I would do it myself. Based on the previous tests what would you calibrate to. At 4000 ppm unit ****s off
    IG ~14,000 Gal
    SWG Aquapure 1400
    Hayward XL Cleaner
    1.5Hp 2 speed
    TF-100
    I'd leave it alone. The SWG is just as likely to be correct as the Taylor test.
    Montreal Canada
    326
    Why not add 4.00 grams of kosher salt to 1 liter distilled water and use that as a 4,000 ppm NaCl standard solution. Dilute it as needed.
    Also, for the Taylor salt test I find it easier to use a 20 mL sample, 2 drops of R-0630, then titrate. Each drop of titrant is worth 100 ppm NaCl, but the endpoint is easier to reach without going over (which is quite easy to do with this kit, you want salmon color, not brick (brick is the color you get when you mix 1 drop R-0630 and 1 drop R-0718).
    Also, there is the salt content (NaCl) and the conductivity of the solution (which is anything added to the water that increases its ability to conduct electricity). The unit looks at that while the Taylor measures NaCl.
