Thread: Sta-Rite heater won't fire
    Sta-Rite 333k NG heater won't fire the heater.
    Starts ok
    Blower starts up
    ~ 30 seconds- 1 min go by and it switches to service heater LED
    None of the fault LED's on the bottom are lit
    The Fenwal on the igniter goes to 3 flashes "Ignition lockout"
    Sound like a failed igniter?
    Pool store closes at 5!!
    30,000 gallon vinyl / Starite pump, Sys 2 cartridge, Max-E-Therm 333k heater / Bioguard SWG
    Re: Sta-Rite heater won't fire
    This hopefully helped: sta-rite-heater-stopped-working-t7119.html?hilit=sta*
    Not the problem, but the mouse nest / chewed wire.
    That got it!
    Jan 2011
    Las Vegas, NV
    8
    Quote Originally Posted by 19redwings View Post
    Starts ok
    Blower starts up
    I know this is an old thread but I wanted to update it in the hopes that it could possibly help someone. I was having the exact issue as the OP, but it would only happen intermittently. I fought with this for 5 years before finally getting it fixed this year. We've had the pool builder, a rep from Sta-Rite, and the gas company all come out over the years but it still never worked right...
    About a month ago, the main board on my Sta-Rite Max-E-Therm 400 pool heater when out AGAIN. We had a technician come out and replace it and when he tried to fire it up, it had the same symptoms (blower starts, 30-60 seconds it tries to ignite but doesn't, then service heater LED comes on). He checked various things and tried a new igniter but it still didn't fix the issue. He then checked the gas pressure and it was only 4"WC with the heater running. He said it needed to be 5"WC or higher. Note: the manual for this heater says it needs a minimum of 4"WC when running, but obviously that's not enough (IMO)
    I called the gas company out and the guy measured the gas pressure with the heater NOT running and it was 7"WC. He also checked with the heater running and it was about 4.4". He said they are only supposed to supply 7"WC but he also knows that these heaters are touchy, so he increased it to 8"WC with the heater off. He didn't check it again with the heater running but it has fired up every single time since he increased the gas pressure.
    So...if you are having an intermittent problem with your Sta-Rite Max-E-Therm pool heater that no one can seem to figure out, be sure to check the gas pressure!
    15,000 Gallon In-Ground Plaster with 3M Quartz with Spill-over Hot Tub, Installed May 2011 | Pentair Intellipro VS3050 Variable Speed Pump | Sta-Rite S7M400 Cartridge Filter | Sta-Rite Max-E-Therm 400 Heater
    Pentair IC40 SWG | Taylor K-2006 Test Kit | Kreepy Krauly Sandshark Pool Cleaner
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Mice love chewing in the ignitor and other wiring in the unit.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
