Thread: I left water in the filter over the winter, and it stinks
    So I was moving my Hayward 166t Filter and heard water sloshing around. I opened the drain and water started coming out and it stunk.
    Do I need to somehow clean the filter now?
    thanks
    Vinyl 18x36 Single Roman End
    ~26,000 Gallons
    Goldline SWG T-15 Cell
    Sand Filtration
    Pool Tool Zinc Anode
    LaMotte Color-Q Pro 11 Test Kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: I left water in the filter over the winter, and it stink
    Start it on backwash to rinse the water out.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    What he said. Be careful where you point the discharge, because it's going to be gross and smelly.
