Thread: One More Question About TA And PH
    Jun 2010
    Tennessee
    138
    Been shocking over the last week my readings from TF-100 Test kit a few minutes ago are
    FC=9
    CC=0
    PH=7.2
    TA=100
    CYA=40
    Water is clearing I can now see the bottom...my question is, do I need to boost my PH up and what do I use...Borax?
    30' Round Vinyl AG, 21,200 K GAL. with Main drain, Hayward 1.5 HP Pump, Sand filter, BBB Method & TF~100 Test Kit
    Re: One More Question About TA And PH
    You don't need to raise PH just at the moment, but if you want to anyway borax is a good thing to use.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Just enjoy the pool. A bunch of kids splashing around will aerate things and drive the pH up anyway.
    Jun 2010
    Tennessee
    138
    Okay it's been a week since I added the 5 lbs. of stabilizer....I did go ahead and up the ph ...my readings this a.m. were
    FC=9
    CC= 0
    PH=7.5
    TA = 110
    CYA= 50
    Water is clearing..got my son in there today to get the rest of the pine needles out and vacuum for me...maybe in a few more days the water will be clear enough to put the wedding cake stairs in.
    Thank you for all your help..I really appreciate it. Oh and I still have a about a dozen 3" trichlor pucks leftover...how much would this raise my CYA if I use them...I really don't want my CYA any higher?
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,110
    Using the pool Calculator and 7ounces per puck....
    Raise FC by 27 and CYA by 17. Lower PH by 1.47
