Results 1 to 14 of 14
Thread: A few ?? about: skimmer, testing water, underlay insulation
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    I just bought our pool!
    Ground is prepped.
    Equipment at the ready!
    Grandkids waiting in the wings. (nag, nag, nag)
    My questions are:
    1) thru the wall skimmer – where best to place this jewel? I don't mean height, I mean in relation to the intake (to the pump) and the return (back into pool). To which side of the original intake? It seems that if I put it between the original intake and the return that that would be too close together for proper circulation. Like they would work against each other.
    2) What do you do with the original intake?
    3) I've read on here to have the pool water between half full and just below point of install before installing the skimmer so that the wall is taut. Is this the general consensus?
    4) I have the TF100. Should I take preliminary readings from the hose? Or should I wait until the pool is full to take that first test? I'm not sure if the huge surface area would affect the results so much, so quickly. I figured the chlorine would change from hose to pool because of the sunlight exposure during the fill time. But by enough to make a huge difference in what ever the pool calculator is going to tell me for that initial chlorine run to the store? Also, I'm excited to have the kit and want to play!
    5) And this is a big one! I am coming up with 23 sheets of 4' x 8' insulation for a 28' diameter circle. I figured on 28' so I'd have a buffer zone around the 26' pool. Any math whizzes out there that are willing to double check my figure? I drew it all out on graph paper and I was somewhat amazed that it'd take that many. For once I'm hoping that I'm wrong about something. Tho sadly, I'm pretty sure it's accurate. This stuff is expensive in bulk!
    Thanks folks,
    Angie
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    30,432
    Re: A few ?? about: skimmer, testing water, underlay insulat
    Either way is fine. Don't test for CYA or FC as you will have none at first (but please get some in right away.)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    If your wind is predominantly from the West.............you'll be better off if you can place the skimmer as far to the East side of the pool as possible. My skimmer and return jet are about 3 feet apart. Jet is pointed away from the skimmer to circulate around the long way back to it. Sometimes I change it just to watch the dirt pattern change!
    docchop1's Avatar
    Apr 2011
    Southern Indiana
    61
    The area of a cirlce is Pi times radius times radius
    The radius is 1/2 the diameter:
    28 feet diameter divided by 2 = 14 feet radius
    so..
    Pi or 3.14 times 14 times 14 = 615.44 square feet
    A sheet of 4x8 insulation is 32 square feet
    615.44 divided by 32 = 19.23
    If this math is correct you could put together a 28 foot circle with only 20 sheets of insulation. That's if you could cut the sheets in such a way that you only waste 3/4 of a sheet.
    Intex 15x48, Intex Saltwater Chlorine Generator, Intex 14" Sand Filter, TF-100 unicorn eating spaghetti while riding a unicycle on a high wire during a storm edition test kit,
    http://tftestkits.net
    Samantha Sabrina's Avatar
    Apr 2012
    Bloomsdale, Mo
    346
    Here is the layout I am planning to use for my foam underlayment, I think you could do pretty much the same thing, only use a few more sheets, like you I am planning a small buffer around the outside of the pool itself.
    Also, don't forget to use concrete pavers under the support legs, just to be safe that something doesn't settle and cause issues down the road.
    I am going to setup the top frame of my pool on top of the foam, apply light pressure to mark the foam, then move the framework, and cut holes for the pavers, sinking them to level with the top of the foam, (people have said they place the legs right on the foam but I don't like that idea myself).
    Hope this helps.
    Samantha
    In the process of building for a 22' Intex Ultra Frame, (completion date up in the air at this point).
    We could not beat our backyard into submission so we "Buried It".
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Thank you all for the responses. A lot to chew over. I had figured the area of the circle but to tell the truth I've turned this thing every which way but loose and I think I fried my brain. I'm going to sleep tonite and hope a few brain cells regenerate. To get it to work with only 20 sheets without wasting more than 3/4 sheet would be a wonderful challenge. Maybe tomorrow. I like a good puzzle or brain teaser as good as the next girl. Dang, now I'm going to have to work on it before I can sleep or it'll keep me awake.
    Thanks again,
    Angie M.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Samantha, your diagram is great! I've got a couple of programs that should do one similar. If I can remember how to use them, I'm going to give it a try and see if I can get the 20 sheets to work out. I'm told that the number of uprights corresponds to the number of feet in diameter. My 26' pool has 26 legs to stand on. I am going to pick up the pavers for under them. Figured that into the budget right off the bat.
    woodyp, I hadn't thought of the wind affecting the skimmer. Thank you.
    Angie M.
    Apr 2012
    Bloomsdale, Mo
    346
    Taterfink,
    I just made you a layout for a 28' x 28' square.
    This would require 24.5 sheets.
    I added the pool area to give you a better idea how it will look.
    [attachment=0:3pocxpgt]28x28_Foam_Pool_Layout-O.jpg[/attachment:3pocxpgt]
    I don't see much way to get by any less if you want some buffer.
    This will give you 1' on 4 sides and more in the corners.
    That is how we are doing ours so we have the foam all the way around under the ground cloth, will make it much nicer for walking around the pool for cleaning and such, plus an area in the corner for the ladder and a place to kick off the shoes.
    If you need to try and get it down some send me your idea and I will see if there is a way to reduce the number of sheets with minimal waste, (CAD programs are nice).
    Hope this helps.
    Samantha
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    FYI, I used Excel to draw out my foam diagram. I drew a 24" circle using the drawing tools, then made 8"x4" rectangles and placed them around to cover. I cut some of the sheets down to 4x4 and some to 4x2 and had very little waste from my 15 sheets to cover a 24' circle.
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Thank you all for the diagrams. I really do appreciate your effort and concern. I went old school . . . yep, graph paper, a compass and a ruler! Here's how I came up with 23 sheets of insulation. I have several programs that would do this but, truly it's been so long since I've used them, I'd need time to refresh my memory. I have programs for digitizing embroidery designs, for the Cricut machines, Google Sketchup 8, to name a few. But, like I said, it's been a while. So I've resorted to a pencil and paper. Go figure!
    I staggered the horizontal seams thinking this would help it maintain integrity (at least in one direction). I'm now waiting on a huge tarp to arrive (30' x 60'). I plan to lay down the tarp, then the insulation, then fold the tarp over top of the insulation. Like an insulation taco? I will of course have the step stones under each of the legs. If I do this just right, I should wind up with a 4' to 6' extension with one layer of tarp that I can use for underlay for step stones on the one side to put the ladder and chairs on. Kind of like a step stone patioish area to help keep the pool a little cleaner. Not as wonderful as a deck would be but, it will work for the interim.
    Oh, the inner circle is the 26' pool. The outer circle is the 28' area to be covered by the insulation. Thus giving me approx. 1' buffer for good looks and outer pool hygiene.
    [attachment=0:1gj38miz]graph2.jpg[/attachment:1gj38miz]
    Angie M.
    Does anyone have this layout for a 20' Intex? I'm putting mine up next month and want to do the foam underneath, but not sure how to figure out how many sheets I'll need and how to cut it to minimize waste.
    Intex Ultra Frame 18'x48"
    Intex 14-Inch Krystal Clear Sand Filter Pump
    Intex Intex Krystal Clear Salt System (not yet installed)
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Well you could draw it out on graph paper like I did or print out the picture of mine. Then count out 10 squares in each direction from my center point.
    Angie M.
    22,553
    Here's a 20' laid out with 4'x8' foam. each small section is a half a sheet. Probably want to buy a couple of extra sheets just to be safe.
    [attachment=0:a2ndxuzl]20' Intex Foam Placement.jpg[/attachment:a2ndxuzl]
    Thanks!!!!
