Thread: Does my Diving Board need to be replaced?
    Hello All!
    We are newbies! We have a diving pool with what appears to be a very old diving board. It feels in great shape and handles the 'big boys' very well...but, we saw a couple of cracks on the underneath side of the board. (We would have never noticed...just happened to look). They are on the back end of the board....the end that is 'screwed' down...not the part you jump on. Anyhow, the cracks just seem to be on a the single layer and don't appear to be growing.
    Do we need to bite the bullet and replace the board or are we okay?
    Any thoughts would be greatly appreciated!
    Ynothd, McDaniels, Ky. 40152, pool 15'x42", 4000 gal, filter system SFS1000, pump type F1000C, gph flow 1075, cheap "inteck" type w/metal ring at top and side legs vinyl above ground pool "walmart special" my first pool
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Does my Diving Board need to be replaced?
    Your description COULD be just cracks in the gel coat, but it's hard to diagnose something like that without seeing it.
    Good point, JohnT
    I've attached pics of the underneath side of our board. I welcome your feedback.
    Thanks again! [attachment=0:ehs9ktbn]IMAG1111.jpg[/attachment:ehs9ktbn][attachment=1:ehs9ktbn]IMAG1110.jpg[/attachment:ehs9ktbn]
    Liz
    Jun 2011
    Long Beach, CA
    2,781
    It looks like it needs to be replaced to me. The last thing you would want is have someone injured from a board that you knew was damaged to begin with. Those are not just cracks in the gel coat.
