Results 1 to 10 of 10
Thread: Cement under an Intex pool?
    We have an 12x24 Intex Ultra Frame pool. The last 2 summers, we had it sitting on outdoor carpet that was just on top of the grass/dirt held down by landscaping staples, but now that the carpet is beyond cleaning we are thinking of pouring a cement slab for the pool to sit on.
    Has anyone done this? Or is it advised against. It would be nice and level, it would be much easier to clean than the outdoor carpet.
    Please share your thought and ideas with me.
    By the way, I just found this site, it is fabulous....I which I would have found it a few years ago!
    22,548
    Re: Cement under an Intex pool?
    Putting it on a concrete pad is a good idea. There was a discussion a few days ago about that very thing.
    Thanks, could you direct to that discussion?
    One more question about this...should I put some type of cushion between the cement and the pool?
    22,548
    I really hate doing this but you can use the Google search at the bottom of the page to search for it.
    It's discussed in that article but it really doesn't matter one way or another.
    I am sorry I guess I don't understand what you hate you doing? It is possible for you give a me a link to the post or article that you are referring to? Or maybe a title of the post so that I could search for it that way? I really need more information on this subject and would love to be pointed in the right direction.
    Thank you
    Here you go Lala:
    can-i-put-my-18-intex-pool-on-a-concrete-slab-t44800.html?hilit=Intex%20pool%20on%20concrete
    Also:
    Q Can I set the pool up on a concrete patio?
    A Yes. A ground cloth is highly recommended, do not drag liner across concrete as abrasions may cause holes. Surface must be level and stable.
    Q What other surfaces can be safely used to set up my Intex Easy Set Pool?
    A The Easy Set Pool can be set up on grass, compacted dirt, or pavement that is completely level and stable. A ground cloth or tarp is recommended. The pool should NOT be set up on sand or muddy ground that could possibly shift. It is NOT recommended to be set up on wooden decks.
    http://sitincomfort.com/intexpoolfaq.html
    Can I have a pool installed on concrete.
    If so, what Type of pool? An Intex or regular steel wall pool.
    Also, if I can install on concrete how can I make that area
    level? There is a slight pitch there for drainage.
    Thanks, Steve
    Hi Steve. An Intex Pool would install nicely on concrete, all you would need would be a pool pad of some sort to set it on. The only problem is that there is no way I can think of to level the area.
    Installing a standard steel wall above ground pool on un-level concrete, however, is pretty easy. Once the bottom rail and footplates are assembled roofing shingles can be placed under the track as levelers. It's best to use a transit while doing this so that the pool turns out perfectly level.
    The shingles allow you to raise and lower the bottom rail gradually simply by adding and removing the layers of shingle used. I recommend leaving enough shingle on the inside of the pool to support the preformed pool cove you should be using.
    Using preformed pool cove and a pool pad when installing a vinyl lined pool on concrete is highly recommended. If the level is not to far off this would work fine. If you are talking inches off, you might consider bringing in sand for the pool base. Doing this would allow you to level the interior of the pool as well as the outer rim. It's the outer rim that's critical, but the liner will install better if the pool base is level also.
    http://www.shadebuilder.com/installing- ... crete.html
    Hope this helps
    Jen
    30,000 gallon, IG, Vinyl, Sand Filter, Hayward Super Pump - 3450 RPM, 1.5 HP
    South Central Kentucky
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    I entered the phrase "set up intex on concrete" in the google box on the bottom left of this page. It pulled up several results. Here is one of them to get you started.
    Love TFP? Become a
    TFP Supporter!
    Fabulous!!! Thanks for all of the help!
    We have a 24 ft round vinyl sided pro series pool and have it on a big cement area. But what my husband did was leave the center dug down and filled it with sand. So only the support braces and a few inches of the bottom of the pool is on concrete. So it saved us a ton on that extra concrete it would have taken and the bottom is safe from being torn up cause its on a bed of sand. Just remember to really get that sand deep and thicker up cause once you start adding all that water it sure compresses. My husband told my friend and I when we were raking the sand to leave it a four or more inches above the concrete level so it worked great when the water was added it ended up being level with the cement pad. Good luck!
