Thread: Plaster and water were done last weekend
    chezdude's Avatar
    May 2012
    Hillsborough, NC
    5
    First post and trying to get the hang of all this stuff.
    I'm in the same situation. Plaster and water were done last weekend, so I'm trying to deal with the "first 4 weeks" issue of not being able to run my SWG but yet still keeping the pool able to be swam in. We just don't have the Houston sun to help warm it up. Just getting up to swim temp today (78 and climbing). We had a leak issue the first weekend (they forgot to cap an outlet in the skimmer...3300 gal lost) and then it rained 2 days this week.
    Anyway, my builder said not to add any CYA to the pool. Is that just a difference of a chlorinator versus a SWG?
    I'm having a dickens of a time keeping FC in my pool, but that's obviously due to no CYA and no SWG. So I'm going to get a feeder and trichlor tablets for the first few weeks (plus still adding shock).
    14,000g custom shape IG gunite/plaster with built-in 7' spa - Hayward 2HP 2 speed - Hayward 450sft cartridge filter - Hayward 400k BTU nat gas heater - spillover on spa and 24" "sheer" water feature - Hayward SWG - Turbo Shark robotic cleaner - ColorRite LED lights - Taylor K-2006 test kit
    Re: Plaster and water were done last weekend
    Just put two trichlor tablets in the skimmer(s) and leave the pump running 24/7 and you will take care of both chlorine and CYA additions and be gentle on the plaster with hardly any effort on your part.
    You don't want to add significant levels of CYA while the plaster is curing, but you can add it slowly, as the trichlor will do. This has nothing to do with the SWG, just a fresh plaster thing.
    chezdude's Avatar
    May 2012
    Hillsborough, NC
    5
    So 1 tab in each skimmer, I assume. The tabs seem to indicate that they do 10,000 gal for 2 tabs.
    One more question, any advice on tabs to use? The standard 3" or the "dual-layer" 3" that are trichlor with a little dichlor (http://www.lowes.com/pd_301388-1772-054 ... facetInfo=). Any reason to use one over the other?
    30,419
    standard 3" tri-chlor is best.
