Thread: any transporting rules for bleach?
    May 2011
    Orillia, ontario, canada
    50
    hello
    I'm curious if there is a limit to the amount of bleach you can personally transport in your vehicle?
    I need to do some shocking and will require lots...
    I'm in orillia, ontario, canada
    Approx 74,000 liter inground vinyl pool 12x32, laser 225 sand filter, Hayward 2 speed pump + old pool heater.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: any transporting rules for bleach?
    I can't tell you about Canada, but in the U.S. it is exempted from Hazmat regulation as a consumer commodity. (at least for 6%), for 12% it is a gray area, at worst it would require carrying hazmat paperwork that identifies the substance, and a limit of under 1,000 pounds for drivers without a CDL with Hazmat endorcement.
    Ike
    p.s. my family has a janitorial and cleaning supply business, so I have a fair amount of exposure to this type of question
    Mar 2010
    Spring, TX
    1,082
    One time I bought 20 96 oz bottles of bleach and trasnported them from the store to home and no one said anything.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Same here. I had 17 182oz jugs of bleach and 12 gallons of liquid chlorine in my truck a few days ago. SHOCKING SUCKS BTW.
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I just wanted to add that people should cosider safety, not just legallity when transporting bleach or liquid chlorine. You would want it secured in an area seperate from the passenger compartment, as I am sure getting soaked with gallons of bleach in the event of an accident would not be pleasant to say the least.
    Jan 2010
    Randleman,NC
    620
    None..The only safety hazard is handling it..Watch the splash-up when you are pouring in...Make sure you wash yourself off..Had some bleach 6% splash up in my face around my mouth..Burn'd a spot on my lip..Had to go to the skin doctor to have it taken care of .
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
