Thread: Regular PVC ball valve vs. Jandy or Pentair valves
    Aug 2010
    Charleston, South Carolina
    77
    I'm not trying to be cheap .....but is there a big difference between one of the "pool" brand valves like a Jandy NeverLube 2 port valve and say a regular PVC ball valve from Lowes? I need four 2" valves and the Jandy NeverLube are $53 a piece compared to $14.
    Inground gunite
    19,000 gallons
    Pentair Triton II TR100
    Pentair Intelliflo 3HP pump
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    I went with the ball valves from HD and regret it. I have 8 of them if I only had 4-5 I would upgrade. With a 3 hp pump you will probably get air on the suction side with the ball valves. I get some with my pump through those valves with vacuuming. Just my
    .02.
    Under construction DIY 20x40 vinyl liner steel wall pool, Pentair 2hp wisperflo, Pentair tr100 sand filter, Pentair Minimax 400k heater, diving board, 8 foot sit n step, xtream waterslide, 1700 concrete deck, one amazing wife, 4 children and two German shepherds.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Regular PVC ball valve vs. Jandy or Pentair valves
    Yes there is. The pool valves are much smoother to turn, are full pipe diameter while the ball valves are generally reduced diameter, and the pool valves can usually be disassembled for repair.
    Sarnia, Ontario Canada
    162
    Guess you know what my vote is. I turn them just for fun!
    20x47' double roman vinyl liner pool. Pentair EasyTouch 8PSC-IC40, 011018 Pentair IntelliFlo, Pentair Clean & Clear Plus Filter CCP420, Pentair 120V IntelliBrite LED, Cleardeck indeck solar reel, 530 sq' solar system Polaris 9300xi robot, Interfab Turbotwister slide, S.R. Smith T7 diving board, deck jets vinyl-liner-pool-build-in-ontario-canada-new-pictures-t30213.html
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I love the price of the ball valves, but they do tighten up over time. Also, with the three way jandy style valves, you end up needing fewer. With that said, every time I think about replacing my ball valves that control flow to my solar panels, the cost makes me happy with what I have. I'm too cheap
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I have 10 Jandy valves and 2 ball valves in my system. The first time I tried to turn a ball valve off the handle broke.
    Hunt around, you can find Jandy valves or less than $40 each online.
    chiefwej
