Results 1 to 7 of 7
Thread: 27'x52 aboveground pool question
    Is it normal for the vertical upright supports to kind of widen out after filling the pool?? Thanks!
    - Brandon.
    27,300 gallon in-ground Gunite pool
    1.95hp AC Smith pump
    150 gpm Hayward cartridge filter
    3 Volkswagens and a 73 Plymouth.
    22,539
    Re: 27'x52 aboveground pool question
    I don't know what you mean by widen out? Can you explain more or post a pic?
    Well you probably wouldnt be able to tell from a picture, but the metal uprights that stand up around the pool and the top caps hook to is what i am talking about.My husband thought some of them just looked wider than others like from weight of water.
    - Brandon.
    22,539
    It's possible but probably not an issue.
    Are they resin or steel uprights?
    Thery are steel.
    - Brandon.
    22,539
    Most likely just an optical illusion then.
    i hope so.
    - Brandon.
