Thread: TA is low
    TA is low
    My TA is running around 40 but my ph is right on. What is the best way to raise my TA without making my PH go all crazy?
    24' round AG pool, 52" high,; Waterway 2 spd Pump;
    150 Sq ft. Clearwater Cartridge Filter & 100 lb Sand Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: TA is low
    Baking Soda
    Re: TA is low
    Thank you.
    jccams's Avatar
    Dexter, MI
    95
    Re: TA is low
    Adding sodium bicarbonate will raise your PH. Just did the same exercise to raise my TA. Had to add acid to bring PH back to correct level.
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
    Butterfly's Avatar
    South Carolina
    10,045
    Re: TA is low
    Baking soda has the least effect on pH. Use the PoolCalculator.com "effects of adding chemicals" (near the bottom) to calculate how much the pH will be affected.
    You're done SLAMing when:
